It is currently Fri Jul 25, 2025 1:14 pm
PostPosted: Sun Apr 01, 2012 7:40 am
Hi All
A thickness caliper such as the one below has been on my list
for quite a while, but there just never seems to be enough "budget"
for it.
I do have one of these though.
and one of these as well
I removed the threaded part of the clamp (the plastic tip pops on & off)
I took a drill bit the diameter of inside the threads on the clamp, chucked it
in my drill press and drilled through the opposing end of the clamp,
I then opened this hole to the od of the dial indicator. I flattened the end of a wood screw,
drilled an appropriate size hole and let it cut it's own thread. Put a doubIe nut on the threaded
rod to lock it in position & smooth the ball end if necessary. I had to do a little fiddling to get
the alignment right on, but it works well & I can take it apart when I want to use it as a clamp.
Hope this is of use to someone!
Bob Hames
PostPosted: Sun Apr 01, 2012 10:08 am
Use what you have, right?
You can also make a frame out of plywood that works well.
PostPosted: Sun Apr 01, 2012 10:23 am
Last Name: Renick
City: Mount Shasta
State: ca
Zip/Postal Code: 96067
Country: us
This is the stuff I had around, the magnetic arm on the drill press trick. In the center of the drillpress table is a 3"x3" hole for inserts, I use an insert with a pin with the dial indicator.
http://shastaguitar.com/
http://www.kalimbakit.com/
PostPosted: Sun Apr 01, 2012 3:20 pm
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
A bit of plywood and a cheap dial gauge.
PostPosted: Mon Apr 02, 2012 5:10 pm
All great ideas guys!
PostPosted: Thu Sep 13, 2012 8:36 pm
First name: David
Last Name: Eddy
City: Mandeville
State: La
Zip/Postal Code: 70448
You guyz think like I do!! [:Y:]
PostPosted: Wed Mar 06, 2013 1:34 pm
First name: Kent
Last Name: Wilkinson
City: New Carlisle
State: Ohio
Zip/Postal Code: 45344
I have learned so much in the short time I have been using this forum. It's great.
